Post by CALL OR TEXT 778-712-3135 on Feb 14, 2012 10:17:25 GMT -8
2008 HUMMER H3 www.edmunds.com/hummer/h3/2008/BASE MODEL SPECS Engine & Performance Base engine size: 3.7 L Cam type: Double overhead cam (DOHC) Cylinders: inline 5 Valves: 20 Torque: 242 ft-lbs. @ 4600 rpm Horsepower: 242 hp @ 5600 rpm Turning circle: 37.0 ft. Base engine type: gas DriveTrain Drive type: four wheel drive Full time 4WD Mechanical center differential Electronic hi-lo gear selection Transmission: 5-speed manual Suspension Short and long arm front suspension Solid live axle rear suspension Front independent suspension Front and rear stabilizer bar Fuel Fuel type: gas Fuel type: regular unleaded Fuel tank capacity: 23.0 gal. Range in miles (cty/hwy): 299.0/414.0 mi. EPA mileage est. (cty/hwy): 13/18 mpg
Post by CALL OR TEXT 778-712-3135 on Feb 14, 2012 10:17:45 GMT -8
